[How To] Replace ICS Smileys With GB Smileys
wiisixtyfour
After updating my Lucid to ICS I really disliked the new smileys in the Messaging app. When I was able to root my Lucid the first thing I did was switch the smileys for the GB ones I was used to. ICS has a few more smileys than GB had so I included some custom ones I found.
I did this by copying the LGUSMms.apk from the /system/app/ folder and extracting it on my computer, then replacing the images and zipping it again and replacing the file using a root explorer.
Here's the modified apk:
LGUSMms.apk - MediaFire
And here's a zip with just the images I used:
GB Smileys for ICS.zip - MediaFire
