shigglyboo
I checked the manual and did a bit of searching, the only good how to guide I've found requires a SD card reader, my laptop that has one is at the repair shop.
I'm wondering if I can just copy everything from the old one while it's hooked up via USB, dismount, unmount on the phone, power down and install the new card and copy the old data.
Only problem is, I'm not sure if this will work and I don't want to mess up my card.
