Help How to reset to factory system?
th4evil
Hello, I have some issues with my HTC Wildfire
I want to get same as it was before I had moded it.
I have moded hboot, clockworkmod recovery, + S-OFF.
Can anyone help me with getting it back due warranty.
Hey man
Erm if you factory reset your Wildfire you will still be rooted ive personally tried it, what you have to do is unroot using an RUU specific for your phone carrier (network provider - 3, T-mobile, Orange, O2 etc.)
Use this link here and scroll down to unroot
Good Luck
Btw if you dont mind me asking, what were the problems that made you reconsider using your rooted Wildfire?
I have used thouse specific ruus and now my system is 2.2.1 but I wanted to know how to remove revolutionary over my hboot and how to remove clockworkmod recovery and make it S-ON
BTW I had touch problems... it wouldn't respond
Before it rooted it touch worked perfecly... i didn't eaven managed to flash rom...
still i need help with HBOOT , Revolutionary, Clockworkmod recovery
Here is a link for to help with your HBOOT, here
Ill help you with your other problems when i find solutions
