Root how to root Casio COmmando 2
Interesting.. I've been way scared to root the new one I have.. but I could do with out the extra icons and apps I don't use...
Once I downloaded the mO50 upgrade, Im pretty sure I also pulled battery while it was installing in progress
. Then a dew days later I installed the deffered
update
After I installed the deffered update MO50, I checked for updates, and it said it was available that it failed to update again. Download failed ,412,
one last thing.... i also had trouble getting the phone to connect to pc( on win xp sp2), so i install the software to try fixxing it((on sp2) and dia back up, then repair....( BACKUP) AND REPAIR) THROUGH VERIZONS SOFTWARE... THIS WAS DONE BEFORE I updated (for the second time) the first time was (the m040 i think right?)to c881M050 so i was at C881M040... pretty sure that is all correct if i can remeber right
not sure if this help but this is the history of thing i have done to the phone thus far besides install lots off apps from f-droid an google apps "store"
