Root How to root Samsung Galaxy Y
as far as rooting is concerned its not possible till now
did u try any hd games
they are not working and i am getting white textures while playing....
iam also looking forward for the root and i tried many methods
gingerbreak 1.2 and superclick 2.1.1 none of them worked
if u managed to run any one of these games
asphalt 5 , assassins creed,gangstar,etc the pm me @ mail2backkids@gmail.com
or replye here .....
sir i have read this from another forum that i am also active....
How to Root Samsung Galaxy Y (crdits goes to MrGambit)
Download the file attached here:
xda-developers - View Single Post - samsung galaxy y root
1. Download needed file (update.zip)
2. Copy ZIP file to the root of your SD-card
3. Turn off your phone
4. Switch ON your device in the recovery Mode
(hold power, volume up, home button together).
5. Select update from SD Card option. (yung volume keys gamitin pang select)
6. You will see that the list of files will come from which you will have to select the file which is named as Update.zip
7. Wait a few minutes
8. And
8. And
your welcome sir
yes sir it works i've tried it last night and i saw the superuser icon on my apps
the question now is whats next? can anyone suggest apps or tweaks for our rooted phone...
8. And
your welcome sir
to make ur device more responsive i have way to do that.
as u r rooted now then using root explorer go to etc folder and verify that init.d folder is present or not.
tell me via private message.
@everyone as many of u r rooted now then before proceeding further wid any action backup ur current stock rom in recovery.
so that anything messes up ur phone then u can restore ur phone to good state any time
after i rooted the phone , when i go to root explorer there is this message that says remount as R/W. When i press on it , it did not do anything. Can you please tell how to resolve this?
Thank you in advance
My friends, I live in Brazil and my galaxy Y came with V2.3.5, I wonder what root can use it, because you have here, at the end of an error where the operation is aborted.
Thank you!
PS: Sorry, but my english is so bad...
1) Download the unroot-update.zip file here - LINK
2) Now copy this unroot-update.zip file into the root folder of your phone's SD Card
3) Switch off your device and restart it into recovery mode using the following key combination Volume UP + Home Button + Power Button
4) You will find your phone in recovery mode with blue coloured UI. You cannot use touchscreen while your phone is in recovery mode.
For making selections and movements, you have to make use of volume up/down keys and make the selection by pressing home key.
5) In the recovery mode menu, there is an option 'apply update from sdcard' Select it.
6) Choose the pasted unroot-update.zip and click on "yes".
7) After the patching of that file, you will be back to the menu, and there it's written "reboot system now". Select it.
8) After the reboot, go to phone's main menu and if you are able to find the "SuperUser" App on it, but once you click it you will notice that it doesn't work anymore, (You can verify it by opening any rooting needed app like Chainfire3D)
Well guys now that you have finally unrooted your phone Samsung Galaxy Y, it will now be impossible for you to run the HD games
See this video for further details: Un-Rooting Samsung Galaxy Y S5360 (Tutorial) - YouTube
Hope this works for you.
Thank you.:cool:
Dont forget to say thanks:D
Did you try to overclock galaxy y???
Is it possible using SetCPU??
Does it work regardless of the version? I have the 2.3.6 ddkl1 version. Or is it there different root files for different versions? The last thing i want is my phone geting bricked. :D
mine is:
GT-S5360
2.3.6 DXLA1
pls reply to my post what tools needed to root. first time rooting my phone. first time in these stuff.
