Root How to Root Sony Xperia Z C6606 with Android 4.3?
How do you root the T-Mobile Sony Xperia Z C6606 with Android 4.3 & Build Number 10.4.C.0.814? Can't seem to find one that works with my phone.
I rooted my Z back before the perf_event exploit was patched so I'm out of touch, but try the latest version of FlashTool first; it is able to root all but the the most recent firmware build. If that's a no-go, perhaps Easy Root or Towelroot will work.
I don't have my xperia z with me to check firmware number but I did update to 4.3 from 4.1.2 (what it came with fresh out of the box)
Towel root worked.
Just go to towelroot.com (I believe that's the link) download apk by clicking the picture.
Install/Open it
Click "make it rain" . It says you're phone will reboot (mine did not). Instead of rebooting I instantly downloaded root checker app to verify.
Congratulations you have root access was the result so I downloaded my su app of choice. Updated binary...
THEN
I finally restart the phone.
Everything worked great. Also installed busy box (get pro version....select smart install) works flawlessly
Easiest root to date for me (my Samsung galaxy light required my pc, odin and a tar file)
