Ok another thread about rooting, as I learn learn learn.
I gaev up on JB for now, because of the gps issue, that aside I now wanna go to ICS rom, but I seem to have run into a snag.
I am using 41g-ATB-cwm-0910 right now.
I downloaded http://forum.xda-developers.com/showpost.php?p=30179536&postcount=3670 aokp_epic4gtouch_milestone-6-20120720.zip
Now when I try and flash it in cwm I get an error trying to flash it that goes somthing like this:
assert failed getprop, goes thru the getprop info, and SPH-d710, then says (status7) and aborts.
My thought from reading on the net and watching videos, there is no FI22 build how-to out there so my thought is I need to go back to gb el29 kernel with cwm 5x then put on the ics roms I want. Is my assumption correct? and could someone possibly make a write up for going from stock ics to ics roms perhaps?
