smoke_weed
Hello i really want to root my phone for live wallpapers and customizations
my baseband : i5700UXJF6
i did the official update from nps by rogers
@yah5
Hi, I'm having trouble with creating a samdroid kitchen on the samdroid forums. Can I select anything on the checkbox that I'd like to include in the KITCHEN? Sorry for sounding so noob I'm just totally new to this! Thanks!
Yeah pretty much. Just keep all the stuff that's initially checked and then add whatever different things you want. If you change the initially checked stuff your phone may not be as stable. Some of the stuff is cool and makes the phone faster but it's mostly experimental and if you want your phone to be able to be a phone, just leave the initial stuff checked leave the experimental components alone.
Thanks! I actually used the guide from your link, it worked like a charm!I was able to successfully install samdroid kitchen in my phone.Thanks! I actually used the guide from your link, it worked like a charm!
