Root How to run a Script in OpenRecovery
asmoler
I would like to know how you can run a script when the phone is in Recovery Mode. I have a .sh file I would like to execute.
This is what I have tried so far:
Use RSD Lite 4.6 to to load a vulnerable recovery for bootloader 90.78. I know that this vulnerable recovery works because I used it to achieve ROOT and to load an update.zip file to do Nandroid backups.
The phone SD card did not have an OpenRecovery/Scripts folder so I created one using Windows explorer with the card in the card reader of the PC. I placed that folder and then. Once more I used RSD to load the Vulnerable Recovery and boot directly into Recovery mode (using the Power Up + X key on the keypad), without booting up to the regular phone mored first.
When in recovery mode I don't have any option to run a script.
What am I missing?
Thanks in advance for any insights!!!!:eek:
