Help How to run GitHub ApkRename step by step
backitup
I want to do answer #3 on this page which promises a 5 minute execute:
"http:\www.android.stackexchange.com/questions/19935/how-to-keep-two-versions-of-an-app-installed"
I have all the software. I have never used Git Hub. All I want to do is run ApkRename and ApkSign. I can't get the GitHub interfaces to work. Where do I enter the data the answer requires? I can get the dos screen to flash but the file is not opened on the phone even in the manager app. Also is a new file created? If so where? Anyone know about this?
Are you trying to do this from a MS/Windows machine via a DOS (Windows Command Prompt)?
If so, that's not going to work (despite what the answer implies).
The scripts (*.sh files) provided in the github link are bash scripts than will only run in a Linux-like environment (i.e., Linux proper, Mac, or Cygwin on Windows).
I have tried windows cmd. I also have something called github, git shell, git bash and git cmd that was installed with the git hub software. You mean this routine can't be done on windows?
A mom
Likely not without something like a Linux environment emulator (Cygwin, for example).
Edit: I tried it on my Cygwin install and it fails with some odd errors...so I'm guessing it's really not meant to be used on Windows :(.
Not what I wanted to hear but thanks for trying :).
