Help how to save contacts to SIM card?
nuke777
even my old huwaei had this option I refuse to believe an all powerful android wouldn't have this simple option.
that sux balls! I don't even know who to blame android or samsung? I guess it is sumsung fault since other android phones have this option.
dude chill :). there is a solution to every problem. download contact2sim free app from market.
yeh I found out about it already. I also installed the latest GALAXO with inFECT'S 2.1 theme and it has the ability to place contacts to SIM without an external prog. I have to a admit I am very impressed with the new galaxo + Dark Sense 2.1 . I am actually quite happy with my i7500 now ;)
any other sugestions for a good kick ass theme?
Must be blind. I can't figure out how to put contacts on the sim...
if you are using the Dark Sense 2.1 theme it has the ability to put it to ur SIM. if you go to ur contacts, press on a any contact and then press menu key, u will have the option to put ur contact on to sim. Unfortunatly it gives me force close therefore I am forced to use an external prog called contact2sim.
