Help How to See Saved Contacts on SD Card
vavagrl
Okay so recently i had to do a factory reset on my cell and i saved contacts on my SD card but also on google. So now the contacts in my cell are doubled. I've been trying forever to find the contact list on my SD card and i'm at a lost. There is no folder for it when i hook it up to my computer and i cant seem to access the card from my cell. I was wondering if any of you know how to view contacts saved to an SD card.
When you open the SD card in your computer, you could enter a contact's name in the search. The results will show which folder it's in.
