Either mount the phone on your windows pc and create folders that way or download linda manager or another file manager from market and use it to create the foldershow do you create folders ?
Easy peasy to understand and follow, thanks for a great reply that helped me out too!If you go into Music and play the tune you want as ringtone, there is a menu item to save as ringtone. It then goes onto your ringtone list.
