danthemanohyea
If you've got root and want to silence your boot-ups and shut-downs, here's how I did it.
Disclaimer:
Method #1:
Method #2:
If you have custom recovery installed on your phone, you can download and install the following files via recovery.
http://coderah.com/moto-triumph/flashable/mt_silent_power_cycles.zip
Credit for this method goes to Merkuralex, thanks!
Disclaimer:
This How-to is meant to assist you in changing possibly critical system files. As such, following this guide is done at your own risk. I AM NOT responsible for anything that happens to your phone that is not anticipated. If you follow this guide exactly, you should not run into any issues, but if you do, you are on your own and can not hold me responsible for any of your issues.
Continue at your own risk!
Requirements:Continue at your own risk!
- Rooted Motorola Triumph
- A Root File Explorer app (I use ES File Explorer, it's free!)
- Download modified power-up sound file: VMU_Power_Up.mp3
- Download modified power-down sound file: VMU_Power_Down_48_24.mp3
- I silenced the audio in the original files. This kept the files the same size but made them have no sound. If the files are just deleted, you'll run into issues (at least I did).
- If you use ES File Explorer, you have to change the settings before you can easily navigate to the locations needed. To do this in ES File Explorer, do the following:
- Open ES File Explorer
- Press the Menu soft-key on your phone.
- Press "Settings"
- Under "Directory Settings", change the Home Directory from "/sdcard/" to "/"
- Under "Root settings", check the "Root Explorer" box and accept the dialogs that follow.
- Under "Root settings", check the "Mount File System" box and accept the dialogs that follow.
- Done.
This will allow you to navigate where ever you need to on your filesystem through ES File Navigator without restriction, so PLEASE BE CAREFUL!
Guide:
Method #1:
- Download the modified power-up and power-down files listed in the requirements section.
- Copy the downloaded modified files to your SD card, I did this by connecting my phone to my computer via USB cable, but use whatever method works for you.
- Using your root file explorer, navigate to: /hidden/data/Power-on sound/
- Rename "VMU_Power_Up.mp3" to "VMU_Power_Up.mp3.bak" (or something else, so long as you change its filename)
- Cut the file that you just reanmed (VMU_Power_Up.mp3.bak")
- Navigate through your file explorer to the sdcard folder where you've stored the modified files and paste the renamed file. In the same folder, copy "VMU_Power_Up.mp3".
- Navigate back to: /hidden/data/Power-on sound/ and paste the modified file. You should now only have the modified mp3 file in this folder, not the mp3.bak file.
- Navigate to /system/media/audio/ui and rename the file "VMU_Power_Down_48_24.mp3" to "VMU_Power_Down_48_24.mp3.bak" (or something else, so long as your change its filename)
- Cut the file that you just reanmed (VMU_Power_Down_48_24.mp3.bak")
- Navigate to the sdcard folder where you've stored the modified file and paste the renamed file. In the same folder, copy "VMU_Power_Down_48_24.mp3".
- Navigate back to /system/media/audio/ui and paste the modified file. You should now have the modified mp3 file in the folder but have moved the original, renamed, file to your sd card.
- Done
Method #2:
