radman2020
Member
The one thing I loved about my iphone was that I could throw a hard switch to silence it when it was in my pocket... You know, you are in the theater and you realize your phone is on...so you can slip your hand in your pocket, throw the switch and feel a confirmatory vibration.
How can I do the same on my skyrocket? If you silence it with the rocker bar, you have to unlock the phone first. If you use the on off switch, you also have to look at it. I don't want to pull my phone out into view.
Any suggestions?
Any suggestions?
