Sak01 Android Expert Jul 24, 2011 #1 I've bought an 8Gb sd card to replace my current 4Gb one which has a 1Gb Ext3 partition on it. What steps should I follow to transfer the contents, including the stuff on the ext partition, over to the new card?
SUroot Extreme Android User Jul 24, 2011 #2 Nandroid backup Copy fat32 including hidden folders to.pc Partition new card via usb mount in recovery. Copy fat32 back Nandroid restore
Usta Android Expert Jul 25, 2011 #5 SUroot said: You should use gparted Click to expand... Otherwise, you will not have an ext3 on the new SD card, so no a2sd+.
Sak01 Android Expert Jul 25, 2011 #6 Got it. I'll stick with gparted but I could have sworn there was another way to partition.
SUroot Extreme Android User Jul 25, 2011 #7 Some recoveries do, but you have to have it already. There are other tools but Gparted is the best, by a long chalk. If you dont fancy burning CD's you can set up VMware player. See new guide in my signature (red link)
