Root How to switch pngs with ninja morph
determined sou
This is the simplest way in my opinion to switch up png images .
This here is to give you an idea if you don't already know , of where the PNG images I switched up are located in .
I installed ninja morph then I installed some apps in the store that give you free icons , one of them is iconspedia the other is icon finder . Then I installed image resizer from play the store . You will need to copy systemui.apk , lgsettings.apk and lgphone.apk from system/app . Paste it in your internal memory's download folder . Also copy framework-res.apk and lge-res.apk from system/framework paste it in your internal sd cards download folder as well .
I'm not going to be providing you with the apks I already messed with because I did not make any of this wonderful stuff , I only switched up a couple pngs here and there . Its up to you to switch them up on the ROM your on and maybe even add some pngs your self seeing that I didn't switch every single PNG .
The folders each tell you exactly where the PNG images are located in inside of the decompiled apk . So it pretty much gives you an idea of where the rest might be located in .
In ninja morph just open it up , the first time it will close with a message . Just reopen it and go to new project then scroll down to sdcard/download then you will see your apks . Select one and it will decompile it for you , after its done it should send you to its decompiled contents . Just back up and do the same for the rest of the remaining 4 apks . Then you can began changing PNG images .
I just use root explorer to switch them but you can also switch them one by one if you'd like with ninja morph . Any questions you guys might have , don't hesitate to ask . I'll be more then happy to help you , you or i could also ask someone with greater knowledge of all this for help .
So after you finished switching them up just go back to ninja morph press on finish project and press on the decompiled apks content you finished working with and it should compile it . Then you copy the apk then go to where it should be . Delete the old one paste the new one fix permissions , do the same for the rest then reboot .
I'll probably also be making a video of how to do everything step by step if you guys want . Looking at how on the motions forum they are cooperating I figured we should too even if it's just a little . Thanks for your time
https://db.tt/QKHzg2Tx
