ok guys
to answer the question as to how you switch off background data on ics.
1. settings-data usage...on Mobile screen switch mobile data on. you will now see Set Mobile Data Limit, click to activate and click OK on pop up, you may now turn mobile data off.
2. On above screen hit menu button you will now be given 3 options Data Roaming-Restrict background data-Show Wi-Fi usage.....tick Restrict background data click OK on pop up.....and your done.
only problem is you now have to live with a white triangle in your notification bar, but if it improves battery life i dont think its too much of an issue
Regards
Baz
Regards
Baz
