You need to ensure that the Dolphin Browser is not set as the Default browser. This can be changed within the settings of Dolphin Browser. After this, when you select the stock internet browser and enter a new URL, it will prompt for you to select Dolphin or Stock browser. Select the Stock one every time that screen comes up or you can just tick the check box for (use as default action)
