Help How to take a screenshot?
Welcome to the AndroidForums, Nicole! :)
I've moved your post here to the Ascend 2 forum so the folks that know your phone best can help you out (I know a way to take screenshots using the Android SDK from your PC, but I'm guessing that you're looking for an on-phone way to do it).
Thanks for signing-up with us here at AF :).
Cheers!
There is No ROOT SCREENSHOT IT (NRSI) app
download it from google play, then download the ENABLER on PC (link on app)
get drivers for ASCEND 2, install drivers open ENABLER on PC
if the phone is detected ENABLE and youre done.
also you can take screenshots of any website using DOLPHIN BROWSER
download SCREEN CUT add on from google play... only works using dolphin browser.
last is to ROOT your phone and download any screenshot app.
hope it helps you..those are the only ways i know!
another one you might wanna try
https://play.google.com/store/apps/...vbS5hbmRyb2lkc2NyZWVuc2hvdGFwcHRvb2wuZnJlZSJd
