R rgr555 Well-Known Member Jul 1, 2011 #1 I successfully rooted my phone. What is a confirmed way of tethering my iPad to the phone? I tried Barnacle wifi app from the market, connected to my phone, but had no internet signal. Thanks
S sdrawkcab25 Extreme Android User Jul 1, 2011 #2 Do a google search for android wifi tethe, it will lead you to the app you need. Here it is: http://code.google.com/p/android-wifi-tether/
R rgr555 Well-Known Member Jul 1, 2011 #3 sdrawkcab25 said: Do a google search for android wifi tethe, it will lead you to the app you need. Here it is: android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting Click to expand... 3) Mount your sdcard 4) Create a directory named "android.tether" (without quotes) 5) Open this directory and copy/move fw_bcm4329_ap.bin into it. 6) Rename fw_bcm4329_ap.bin to fw_bcm4329.bin 7) Install the latest versions of "wireless tether" Im NEW to root. How do you do #7 ???
R rgr555 Well-Known Member Jul 1, 2011 #4 Nevermind, watched YouTube - ‪How to install .apk files on Android‬‏ It's ridiculous how instructions assume person knows a,b,c already Good luck guys
S sdrawkcab25 Extreme Android User Jul 1, 2011 #5 rgr555 said: 3) Mount your sdcard 4) Create a directory named "android.tether" (without quotes) 5) Open this directory and copy/move fw_bcm4329_ap.bin into it. 6) Rename fw_bcm4329_ap.bin to fw_bcm4329.bin 7) Install the latest versions of "wireless tether" Im NEW to root. How do you do #7 ??? Click to expand... There is no need for those steps(4-6), just download the app to your phone and run it. The easiest way to do #7 is to go to the linked page above from your phone and download directly to your phone... Glad you got it working.
