HTC desired
Member
Does anyone know how to theme leedroid I want the battery circular black but dont have a clue how to but it on any suggestions??
Was in the same boat as you. Rooted and flashed Leedroid but wanted a different battery. Got the circle battery mod, then wanted custom notification bar icons. Went to the UOT kitchen and made my own. Put the file on SD then flashed with ROM MANAGER. Worked a treat!
You can change them to any colour or style in the UOT kitchen. Just go in, do your mods, they even give you a preview, select ur ROM from their list or upload a file from your computer, and wait while the kitchen cooks a zip file. Download it, copy to SD then flash from ROM Manager.
It sounds worse than it is, it's actually really easy! Go have a play with it, its the only way to learn, and I'm a total noob!
When I go in I can only see the circle battery stuff, where is everything else?
Was looking to do something with the wifi & signal strength icons.
I know I'm thick!
There's a next button after each mod. Use it
