geofferey
I've created a script for this process and attached it to this post. You can use Script Manager from the market to run it or install using option in script. Make sure to run the script with SU privileges when starting with Script Manager. If you plan on installing script to /system/bin/ so it can be run through terminal emulator or adb shell by typing 'backup', please make sure it's ran from the /sdcard/download/ directory or make sure a copy resides there.
My script can be found HERE on GOO.IM
THESE STEPS ARE NO LONGER NECESSARY
- just to find mounts for backing up
Screenshot of NAND backup Tool:
SGH-T759 Nand Backup & Tools v2.5 by Geofferey Eakins, on Flickr
How-to create Heimdall Package(s)
Step 1: Click "Utilities" tab > Under "Download PIT" click "Save As..." > Name your PIT > Click "Download"
Step 2: Click "Flash tab" > Under "PIT" click "Browse" & select the PIT file you saved in Step 1
Step 3: Under "Partitions (Files)" click add & choose partition type from "Partition Name" > Click "Browse" and select corresponding file for partition (ex: for FACTORYFS you would choose factoryfs.rfs) Do this for any partitions you would like to include in Heimdall package.
Step 4: Click "Create Package" tab & fill out all the information, once filled click "Add Device" then "Build"
Afterwards you may restore using "Load Package" tab
HERE is a Custom Stock Rom based on AreaRomX on AndroidArea51. I will post an "OFFICIAL" thread (when I'm not feeling so lazy) detailing the changes and I will be releasing more updates to it in the future. It also includes my Nand Backup Utility & Tools.
My ghetto changelog
Code:
#mount
Code:
#mkdir /sdcard/NAND
Code:
#dd if=/dev/block/stl9 of=/sdcard/NAND/factoryfs.rfs bs=4096
Code:
#dd if=/dev/block/stl10 of=/sdcard/NAND/dbdata.rfs bs=4096
Code:
#dd if=/dev/block/stl11 of=/sdcard/NAND/cache.rfs bs=4096
My ghetto changelog
