if you go to settings/applications/ manage applications u will see tabs at the top that should say downloaded running all and somethin else. pick all. go to indivisual apps and select them. if the app is able to be transfered to the sd card there will be an option for it i belive in the second box?Sorry I'm new at the android OS. How do you Transfer app to sd card?
I been looking at settings but havent figured how to do it.
I use the app from the marketplace Apps 2 SD free, there's a paid version, but the free one works for me. When I download any app, if it's able to be moved to the SD card, then the Apps to SD notifies me that it can be moved and then a couple of clicks later it's moved.
Seems like a waste of time and memory to get the "app to SD" app. You can do it yourself by going under manage apps in the settings and simply scroll through and send them to SD if it can. Doesn't take that long considering I doubt anyone has a TON of apps to scroll through since the Optimus S has a low memory for apps.
Hope this helps!The main reason would be to free up internal phone storage. A disadvantage is for some sd enabled apps you won't be able to use their widgets if they're on the sd card. Pandora is an example of that.
