Hi,
With a lot of apps eg, camera, pictures appears in the gallery immediatley,
but some apps like Dropbox or blackmoon Attachsave, if you put a picture or MP3 or whatever on the card, they can not appear for ages.
One way on my Galaxy Apollo is to plug in USB and go into storage mode, it then scans the disk (A little icon in the status bar) and the media is now there.
A more extreme way is to unmount the card and then physically remove it and re-insert (I dont have to remove the battery) and it sets off a scan.
Is there anyway to trigger a media scan from within android to make it quicker for stuff to appear?
thanks
Jeff
thanks
Jeff
