I think You have all needed files
Follow These Steps.
1) Install MTK 6573 Drivers
2) Remove Your battery from Mobile
3) Connect the USB Cables to computer and Phone (Keep in mind Battery is Removed)
4) Open Flashtool and load Scatter File from New Version
5) Now Select the Format + Download tab in Flashtool
6) Now the Falshtool is started Searching Your Device
7) Now Insert the Battery
8) Wait for the Completion..!
Done...!
(Look most Important thing is that Drivers should be installed properly..
This may Help You..!
Good Luck..!
