How to undo root
Nickk
Can anybody give me a quick tutorial on how to unroot the vibrant and go back to normal for warranty purposes?
go to your terminal and run adb
here are the commands you need to un-root
adb shell
su
rm -r /system/app/Superuser.apk
rm -r /system/xbin/busybox
rm -r /system/bin/su
Or you could just do what the mod posted :D
You wouldn't have to worry about wiping any important info off your phone that way.
To put it more specifically if you are keeping the phone the best way is what I had listed, if your returning the phone to the store you would want to do what 2FR35H suggested...
just installed adb, now do i hook up the phone and type the commands in terminal?
Is there a tutorial on how to work adb?
This is how you do it on a PC it may be slighlty different for mac but its the same idea.
Hook up the phone go to command prompt then type in the location of adb tools then hit enter a list of commands should pop up as well as info on the device if its connected then type in adb shell then hit enter then continue on with the commands and make sure at the end of every line of command you hit enter. Then after that you should be good.
