Root How to unroot c811?
tmord1
My phone recently received the verizon ota for the commando 4g (M050). I rooted the phone using motochopper so that I could remove some of the bloatware on the phone after the update. Since doing so, the phone is overheating terribly and the battery drains very quickly. Is there a method to 'unroot' the device. If there is, could someone post the steps. I would like to take it to a Verizon store to be checked out, but would like to remove root first. I have searched, but was unable to find a way to remove root after applied. Thanks for any help.
When this happened to me, a hard reset made it a brick, then I called Verizon about a bad update for a replacement.. if I was you I would NOT hard reset it, removing super user icon is enough to fool the sales reps. Good luck
