What if I just did the update from sprint? I know they say you will "never" be able to root, but its just a matter of time.
Factory reset does not work. I downloaded the RUU and ran it how it was explained and I get an error half way through saying it cant read the phone because its not connected to the usb?
And if you get the 30% battery error then you need to manually put your phone into bootloader mode by powering on while holding vol down then choose reboot bootloader then run the RUU exe.
Here's a writeup I made on how to unroot the EVO. If all you did was run the unrevoked reflash desktop app, then hopefully my writeup will work good for you.
If i'm in the wrong by posting a link to my blog then mods please delete. I wont be butt hurt ... Just thought I could help.
