How to update to 3.3 on unlocked for T-Mobile?
surgerush
I have an unlocked Active and using it on T-Mobile. Is there any way to update to 3.3? When I use the software update in the settings, it says it's up to date. I've also tried using Kies, that also says that it's up to date. Any other options or anything else I can try or am I just stuck with 4.2.2 since it's on T-Mobile?
I've rooted and used custom Rom's on my phones in the past, I just don't want to get in to that again and go through all the work, so I'm trying to just keep it stock this time.
Thanks for any help in advance.
What device do you have and what firmware u running . mf1 or what . the only way we can help is if you help us . helping us with what device you have and software you running
I want to know if I will be able to update to 4.3 or if I'm stuck with 4.2. I'm not rooted, I'm hoping to be able to just stay stock this time.
No you wouldn't get T-Mobile update cause your phone is a at&t and your a T-Mobile unlocked free agent to roam
Your device is at&t you unlocked to T-Mobile and running on T-Mobile in order to get the update for your phone u will need to put back to at&t cause that is the original software that is on the device was made for at&t so at&t 4.3 will be needed T-Mobile may not have one yet.when I say put back I mean remove T-Mobile activities
