D DannySihapanya Member Mar 4, 2013 #1 Since I'm rooted, I wanted to install HTC updates but it always goes into team win recovery. Is there any way to make it go into normal recovery?
N negamann303 Android Enthusiast Mar 4, 2013 #2 DannySihapanya said: Since I'm rooted, I wanted to install HTC updates but it always goes into team win recovery. Is there any way to make it go into normal recovery? Click to expand... huh? you only have one recovery that i'm aware of...
D DannySihapanya Member Mar 4, 2013 #3 negamann303 said: huh? you only have one recovery that i'm aware of... Click to expand... Oh, well I can't install updates with the recovery I have now.
OverByter Resident Slide Rule Guru Mar 5, 2013 #4 You would have to be stock, including recovery to be able to receive ota updates. What are you trying to update? OB
A arcticfix Newbie Mar 5, 2013 #6 OverByter said: You would have to be stock, including recovery to be able to receive ota updates. What are you trying to update? OB Click to expand... same as OverByter said
