W WuSoLo Newbie Nov 18, 2010 #1 I had d/l this firmware in Zip form. I tried using the Odin3 1.52 to flash into my phone / copied it into SD Card by using recovery mode to do it ... failed. Can anyone tell me how to do this upgrade cos' I cannot using Kies to get any upgrade outside USA. Many thanks ...
unscrew Newbie Nov 21, 2010 #2 [HOWTO] Update to JH7 using Kies Mini (USA) - xda-developers This is exactly what I did. Works perfectly. Make sure you're in TWlauncher when using Kies Mini. Good Luck!
sremick Android Expert Nov 22, 2010 #3 The Kies Mini method is mentioned in the Captivate FAQ, which is always a good place to check first: I897UCJH7 - CapFAQ
