How do I get face unlock on my Galaxy s2?
Using Samsung Galaxy S2 model GT-I9100M on OS 4.0.3
I went around and played with all the settings but I can't seem to find it. It should be in security with the others but I can't find it.
Any help would be appreciated.
the only administrator set was Cerberus. after disabling it, I still can't pick anything less secure than pattern combination for the phone...what the hell?![]()
Didn't even know it was on this phone until I saw this thread. It works perfectly but my only worry is that well I'm sleeping my family can unlock the phone by pointing it to my face.
I ran into the same issue setting up VPN connections yesterday. Do you have any certificates listed in Settings/Security/Trusted credentials? If so that's the reason - this level of security is required to use credential storage.
You use the "Clear credentials" option in Security and should then be able to set a less-secure method, but if an app requires credential storage it will probably complain.
they can keep you from disabling pattern protection with them?
