P praviN81 Lurker May 26, 2011 #1 There is no options in fit for use only GSM or only HSDPA mode... Its continuously changing into the Edge , 3G , HSDPA. How to use it only GSM or HSDPA mode
R rollno438 Lurker Jul 27, 2011 #2 Go to 1. settings > wifi and networks > manage mobile networks > 2. Disable 'use packet data' and 'data roaming' 3. Enable 'use only 2G networks' With this you`re done. Apart from this you can also do the below 1. settings > accounts and sync 2. Disable 'Background Data' This will de-sync your gmail a/c with your mobile thus not allowing your mobile to download anything from online market. Caution: you have enable each one of the above in case you want to download / install anything from internet/market using your mobile. Regards, Teja
M mahni1390 Banned Jul 28, 2011 #3 settings > wifi and networks > manage mobile networks > Enable 'use only 2G networks. this would solve your problems. مهاجرت کانادا
