Do you know of a free way for me to do this cause cdma workshop looks like its $75+. I can buy 2 samsung moments for that.Your using the sprint employee prl. This allows Sprint employees to have 3g even when roaming. You need to install a customer sprint prl using cdma workshop
as far as I know cdma work shop is the only way to manually replace a prl.
Google is your friend![]()
