I've tried four file managers and an app called SD Reader and none of them show the EXT partition on my external SD card. It clearly shows on my PC when I run an app called "Linux Reader". Does anyone know how to get that partition to show up?
I have tried Easeus, Ext2explore, and Diskinternals and there is no EXT partition on my external sd card.
You would have had to create the EXT partition using a partitioning program like Minitool.
Or EASUS PM, both will show the partition as Ext2/3/4, but you will not be able to read it - but they will show it.
Or do you mean "show up" on the FT3?
So why use ext2/3/4 on the FT3 when only link2sd supports move apps to sd on the FT3 & its clones, and link2sd supports 2 x fat32 partitions - no need for ext2/3/4 at all then.
