Hello,
Not as familiar with the Moment as the Hero... Can someone tell me an easy way to write a custom PRL to the Moment? It is simply a few key strokes on the Hero but I am told the Moment needs CDMA Workshop to push the PRL.
Hello,
Im having a similar problem. I just got a samsung moment and im trying to use CDMA workshop but i cant get it to pop up on the com ports. Its puzzling. I installed some drivers i found for android but its not working out. I read some place that you need to disable mass storage but i also read that it dose not have mass storage????
SWEET, figured this out! So if your moment will not issue a com port you have to go to MENU>WIFI SETTINGS> Bottom of the list turn on dial up networking. Then It will show up in ports in device manager. Making accessible through CDMA workshop.
