how to?
volball
new to the hero and i have a question. i have installed sms text to replace the hero app and now whenever a text comes in i get notification for both apps. how do i disable the hero text application? i dont really want to unistall it, just disable it. i'm getting the same thing with the voicemail program. any help is appreciated...
go into your stock sms app and go to settings and uncheck notifications and your good to go. your voicemail issue, I can't help you with. Not sure why that's happening
