Help How to..
lalamms
hello androidian..
im using samsung galaxy 5 with android 2.1 firmware..
i found that all the application was installed in my internal memory that is in phone memory..
so, how can i change this.. to install all the app in the memory card..
thanks you..
in the memory settings you select an app. Some can be moved with a click of the install on SD button.
