Root How to ?
Chess101
Member
How do I remove a App from a backup? Is this even possible? I have a music downloader app in a previous backup that I cant find on play, and am curious if I can just pull the app from the backup?
If you sign into play store on your computer... on the right hand side near the top there will be a link called My Android Apps. This will show you all the apps you have ever installed on your phones and you can install any app from there straight to your phone.
Hope this helps.
Hope this helps.
I forgot about this:pound: Thanks let me try
Went the appextractor route, Thanks
Btw, for some reason in my downloads folder in play it doesn't show up. Either way I got it to work thanks again
Maybe the app is gone from the Play Store all together. I had an MP3 downloader earlier this year that isn't in the store anymore. Just a thought.
