Root How unbrick ZTE warp sequent no matter what
its not possible to unbrick from certain things. if you do something completely and utterly (for lack of a better word) stupid, you will just be done for. there is a tool similar to odin for zte phones but it is not well supported at all and we have no way to use it on our phone. also, if you updated to the new b11 jellybean update that doesnt work anymore. you have to flash cwm onto the phone then root, but at the same time there are advantages to that method
cwm enables you to make a full backup of your phones system, if you make a backup, then root with the provided zip, if something were to go wrong you can recover from the backup you made, though the chances of something going wrong are slim to none, the biggest chance is user error, which unless you flash a rom not built specifically for this phone aka not found in the all things root section for the warp sequent (not the warp, not any other phone, not any other site other than unleashedprepaids.com which generally has the same content) or damage cwm, you can always recover from
my recommendation is if you want to root your phone get cwm on there using the fastboot method, then make sure apon exiting you tell it "yes" when it asks to disable recovery flashing. if you arent brave enough to venture that far in, well then i guess youll just have to make due with what you have
  • Like
Reactions: Mikestony
Upvote 0
what do you mean by disabling recovery flashing and how do i do the fast boot
Upvote 0
ok here it is step by step
step 1
download my C++ modular all in one tool
step 2
plug in the phone
step 3
use the recovery installation function of my tool in fastboot instead of terminal mode
step 4
wait to see if it gives you an error about checking your drivers
if it does, leave the phone at the black screen with the green guy, see my tutorial on checking your drivers, and instead of selecting adb drivers in the end of manually forcing select kernel debug
then after drivers are properly installed pull the battery and try again
step 5
flash the root.zip which can be found in the all things root section
step 6
hit reboot on the cwm menu, then when it asks if you want to disable recovery flashing, select yes
step 7
do a happy dance, or crack open a cold brew, or both
be sure not to spill the beer while doing the happy dance
step 8
come back here and let us know it worked out
otherwise feel free to ask for more assistance, and also alot of questions have been answered already so you can just look through the all things root section to find alot of information on things such as this rather than having to wait around for my sarcastic ass
Upvote 0
step 7
step 8
lol im only 15 thanks junkie :D
  • Like
Reactions: scary alien
Upvote 0
BEST TECH IN 2023
Smartphones
