biggiephil
I'm quite unsure what to do if I **** up a ROM or port installation. I've always did the KDZ and re root, there must be an easier way is there? Maybe via recovery and backing up and formatting /system?
i use lokid recovery and just flash bobz from there and then goto 2ndinit and restore.
just flash bobz without doing a reset or wiping data. you will have to reapply the fixes though.
yea oh and gapps
i do it all the time. i only wipe data when i want to start fresh for whatever reason or when i switch to stock or vice versa
install recovery 6.0.2.7 from neeshers multitool then backup any data in pictures,music or downloads folder etc... then go into 2nd init 6.0.2.7 and goto mounts and storage and format /sdcard. thats the internal sd. that should fix your backlight issue. works for me anyway. it leaves /data intact
