i havent managed to get a gps lock on it yet though i have tried a few times with and without agps. on my n900, lock is within 5 secs with agps, and around 30s-1min without and works like a charm. i am not impressed with the dhd, nor with the fact that maps are downloaded on the fly instead of being able to download offline. unless i am missing something...
Not true - go into Google Maps, hold down yer thumb on a place you wish to navigate to and after the location appears simply select 'Navigate'. As simple as that.Can't select a point on the map and get it to take you there. You have to input a location or post code.
Again untrue - Google Nav has free voice navigation, however the instructions suck, e.g. instead of saying: 'Take the third exit on the roundabout' it says: 'Take the exit towards the Berwick/Something/Something/Something'. It's quite confusing. Plus the accent sucks as well.You have to pay for voice navigation too.
... Untill getting my HD, i was a Nokia user and had used Ovi Maps a lot. Yes it was great for a free satnav, but i tested it a lot with destinations i already knew, and found it chose very strange routes that often took longer, dispite which style of route i told it to use. I'm yet to test CopIlot as thoroughly, but i will as soon as i get a car holder.
...the 22Gb of music I need to fit on ...![]()
Messing? One app opens another. Can't see anything difficult nor time consuming here mate.Doesn't work in Navigator , and don't want to be messing between two apps to do a simple thing.
