Actually thats not necessarily true. With newer processing technologies making the processors smaller ie, 32nm to 25nm, those newer, processors take up less power and have the potential to be equal or faster in speed because they use less energy. This concept is working for both the laptop and the mobile markets. Using less power equals better battery. For example, the razr maxx has two cores. Two cores should equal more power unless the manufacturing process is smaller allowing for less power usage per core. The Maxx gets two whole days of usage or one to one and a half days of heavy/ moderate usage.its a very common issue for most of the newer smart phones, faster processors drain more battery life..slower processor..well no one wants them
they will have to research on making better batteries. only this that works i to see if you can find a bigger battery, more MAH (which requires diffrent casing too).
[Edit: I do feel kinda bad about using the razr as an example as it has a 3200 mAh battery but laptops are still a good example of how we are seeing longer battery life]
It seems a bit better with 2.3.6 than 2.3.4, at least in terms of standby time.
Cool, but I'm not sure if I trust $20, that's way to d**n cheap bro!
install JuiceDefender. i use my phone a lot. i charge it from 11:30 pm to 6:00 am and 100%. at around 9:00 pm the battery is at 30% to 40%
