Root [HOWTO] Wifi Tethering
yatimameiji
I dont know why no one wrote this one up. Its very simple.
UPDATE:
I'll leave the stuff below for posterity, but there is a new and better way to do wifi tethering. The folks at xda found a way to enable the Mobile AP part of Galaxy S and port it to the Vibrant. Enjoy
Mobile AP App Fixed to Work on Samsung Vibrant | xda-developers
1. Root your phone
2. Google search: Android wifi tether
3. Should be the first link for android-wifi-tether - Project Hosting on Google Code
4. On the side in the green box is Featured Downloads. Select the latest version, at this point in time its ver 2.0.5-pre8
5. Download and install
6. Run app, it will ask for SU permissions when you start and stop tether.
Notes: Encryption works and just for kicks I would say turn on Access Control(MAC filter).
Not the best speed, but then I'm in my workplace and signal is a bit low.
better speed than I get lol.... I get 800kbps down and 750kbps up but im 227 miles from the nearest speedtest.net server.
im using the same program for teather which seems to be really good. I did use encryption and mac filtering lol seems to work great.
good little writeup btw.
So someone please explain to me the difference here between this program and pda net tethering program and is the connection speed for stuff like .torrent downloads going to be considerably different using this instead? More then anything will I be able to use my vibrant as a wifi hotspot for online gaming on my xbox?
My understanding is pda net is 'Wired' tethering, while this program uses the built in wifi radio to make it work like a wireless access point(ie the stuff in your home router that gives you a wifi signal, ya).
Ummm don't be stupid and use bit torrent, you'll probably reach your cap in no time and get put in the slow lane. And I wouldn't use it for any sort of hard core gaming as well latency counts and as you can see my ping time is rather long.
so your telling me tmobiles unlimited, isnt..... niiiiiice.
ive used utorrent and pda net since i first had a G1, always seeeeemed consistant in dl speeds... never was really testing back then though.
any idea what the cap is? ul/dl separate or is it all in one up
+ dl?
thank you so much for this guide. not having internet at the house anymore due to lack of funds has been evil. i streamed an episode of bleach from crunchy roll thu my PHONE ppl. my PHONE. i dont think you realize how epic that is LOL.
I have installed this, but cant get my Ipad or my PC to see the AndroidTether ssid. Am I doing something wrong? I am rooted and ready to go
Nevermind everyone, got it working, had to uninstall and reinstall the newest APK 2.0.8 and it worked like a charm!!!
Very awesome. I love this phone...rooted it in about 2.5 min and got free wifi tethering in about 1 min. Don't get any easier than that!
If you are on the road and dont have WIFI for your Laptop or Ipad, it makes your cell phone a HOTSPOT, until the Vibrant gets Froyo we dont have this option
I did this to my rooted vibrant and it always just says that my phone is in an unknown state...what does that mean?
Are you trying the Wireless Tether app? Make sure you have the latest version. But I would recommend using the Mobile AP mod that reintegrates the original wifi hotspot functionally this phone had.
i use easy tether it seems to run smoother than pda net ive not got a rooted phone but i would also like to know if i use easy tether or tethered it via root will it run off my network ie edge gsm 3g etc or can it pull wifi service from my dlink router at home
