Looks like the original poster abandoned this thread so I'm hijacking it to request help on this topic.
I made the mistake of attempting to load ICS on my HP Touchpad while trying to help my son with his homework and listening to my spouse complain about a quilt she was doing and ran out of fabric. And, I screwed up...
What first happened was that I used Installer3 instead of Installer2 because I was unable to find a copy of Installer2. After installing, my Touchpad would loop through attempting to load Cyanogen then, after failing it would go back to the menu screen and try again.
After finally fining Installer2, I reloaded ICS and I still have the same problem.
So, my HP is NOT bricked, it just gives me a menu that I must select WebOS to get my HP to work.
Question:
Should I use Webdoc to reset things? I'm assuming it will also clear the partition with Cyanogen.
