D
Deleted User
Guest
I'm running CM10 circa 2013. I don't know what patch you are referring to, but isn't the internal memory partitioned? if yes, then I think it *could* matter if you move stuff.
I could be incorrect; I was looking for and asked for a more descriptive explanation. I'm far from stupid. (Most of the time). :smokingsomb:
How am I supposed to know what patch? That was my question to vinodhc, so you will have to wait for his answer.
I don't get your question. If you want to know how the CM team sets up the memory partitions for the CM install, you will have to ask them. What I am addressing here is that moving 50 apps to ones FAKE SD card causes it to unmount. J.C. Sullins created a patch that robs up to two megs of memory from that allocated to the SD card and assigns it to the internal memory space. This gives one additional internal memory and hopefully enough that there is no need to move apps to the FAKE SD card.
Did you even read my first reply to you? I thought I gave a very detailed explanation of why one would want to increase their internal memory and not move apps off to the SD card. I originally injected myself into this discussion because every time Colchiro gave a logical answer to you and johna2u, it's like you two were not getting it.
It's very simple, try to move more than 50 apps off to the FAKE SD card and it will become unmounted. Use the memory fix provided by J.C. Sullins to increase one's internal memory, problem solved. Another easy fix for this would be not to try to install the entire Play Store on one's TouchPad.
