tsmallz2012
Anybody know if this will fix MMS prob on cm10
http://forum.xda-developers.com/attachment.php?attachmentid=1428768&d=1351130301
Why would you need the unbrick guide for any of that?
With a mms fix? Seriously? Lol. You realize it doesn't do a whole lot more than change the apn settings right?
ui_print("*************************************************");
ui_print("* *");
ui_print("* *");
ui_print("* Epic 4g Touch *");
ui_print("* METROPCS MMS FIX *");
ui_print("* Jellybean *");
ui_print("* by -OAKIEVILLE * *");
ui_print("* *");
ui_print("* *");
show_progress(1.000000, 0);
unmount("/cache");
format("ext4", "EMMC", "/dev/block/mmcblk0p7");
mount("ext4", "EMMC", "/dev/block/mmcblk0p9", "/system");
mount("ext4", "EMMC", "/dev/block/mmcblk0p10", "/data");
ui_print("Metroizing system...");
delete("/system/app/DeviceManagement.apk");
delete("/system/app/DeviceManagement.odex");
delete("/system/app/mms.apk");
delete("/system/app/mms.odex");
delete("/system/app/Mms.apk");
delete("/system/app/Mms.odex");
delete("/system/app/MMS.apk");
delete("/system/app/MMS.odex");
package_extract_dir("system", "/system");
ui_print("done...");
ui_print("Metroizing data...");
delete("/data/data/com.android.providers.telephony/databases/telephony.db");
delete_recursive ("/data/data/com.android.mms");
delete("/data/dalvik-cache/system@app@mms.apk@classes.dex");
delete("/data/dalvik-cache/system@app@Mms.apk@classes.dex");
delete("/data/dalvik-cache/system@app@MMS.apk@classes.dex");
package_extract_dir("data", "/data");
package_extract_dir("tmp", "/tmp");
set_perm(0, 0, 0777, "/tmp/mytweaks.sh");
run_program("/tmp/mytweaks.sh", "mytweak");
unmount("/system");
unmount("/data");
ui_print("* *");
ui_print("* *");
ui_print("* u've been Metroized *");
ui_print("* oakieville style *");
ui_print("* E.S.O.V *");
ui_print("* *");
ui_print("* *");
ui_print("* *");
set_progress(1.000000) ;
)i dont understand why people do this crap:
there is teh updater script. by using hard coded lines like i bolded means t hat you do risk messing up your motion if you flash this (unless your mmcblk0p7 happens to be ok with being formatted)
a few changes and this could be instead made to work on any device and work fine...
regardless youd need to check and see if that mms.apk even supports mdpi as teh e4gt is hdpi
