addictedtocars
So I sent an email to HTC asking about the availability of the desktop dock/charger sicne due to poor battery life I wouldn't buy a Bolt until the charger was available, so here is their rather interesting response:
At this time, we do not have any information on when this acceesory will be available for sale in Verizon's retail stores. We are aware of a number of complaints about the battery life and we are looking into it through the software of the phone. We hope to have an update available in the near future to address these concerns. In the meantime, you can perform some steps to try and minimize the battery use of the device.
Try rebooting your phone every few hours. Rebooting your phone clears the phone internal memory and shuts down programs that may be running in the background and using battery.
Try turning off the data connection when not in use. Data connections in the background and syncing can cause the phone to use more battery even when sleeping
You can set your display to brightness to auto. Allowing the phone to adjust the brightness allows for optimal viewing while conserving as much battery as possible.
Setting a static (not a Live Wallpaper) can save some battery life.
If you are not in a 4G area, you can download a widget from the Android market that can toggle the 4G antenna.
I do apologize for any incovnenience that you may have experienced.
