Rootofallevil
Hi All,
After a long internet research, I believe I have a problem which is either really unique or really stupid ("Have you tried turning it on and off again" Level).
Background:
I have:
I am trying to Root it using Unrevoked3 (unrEVOked recovery reflash tool v3.32) and get the following message: "Waiting for device. Plug phone in now and enable debugging. Make sure HTC sycn us *not* installed!"
So there is a communication issue, however, when I use the option "Disk drive" without debugging, I can read the Disk Drive.
I have performed all of the below steps:
The reason I highlighted the fact that I never installed HTC Sync on this laptop is, that the only thing I can think of that might be missing is a driver that comes with it, which stays after you uninstall it (This is so far my only guess of what could be the problem).
I didn't install HTC Sync to verify this theory for two reasons, the request is to have it "uninstalled" and I am restricted from installing it on the laptop I have handy. So before I use a different laptop or try to setup a VMware to verify this, I thought it would be best to pick your brains. By "this" I mean, the action of installing and Uninstalling HTC Sync (to maybe win a needed driver which may be missing).
Any help will be highly appreciated. And to be a bit bold, please try not to direct me to rooting guides or any general troubleshooting knowledge bases, unless you have a good reason to believe it is the same issue.
Thanks so much for your help,
Background:
I have:
- HTC Desire (By Telstra)
- Android Version 2.2
- Software Number (ROM) - 2.26.841.2
- USB Debugging mode on
- Never installed ATK and HTC Sync before on this laptop
- Turned Phone’s Wi-Fi off
- Have Disabled installation of non-Market applications by going to Settings > Applications.
- Made sure to set ‘Charge’ as the default connection type when connecting my phone to the laptop via USB.
